i just did a reset and everything is working besides the Instant Aliases
Thank you for your report, this issue has been logged with our development engineers.
RH-90134 Instant Aliases: OptionsExport Import does not Save Instant Aliases
ExportSettings and ImportSettings do support Instant Aliases, I’d give those a try and you should be sorted.
why are there two methods to export import settings? so is Options Export Import not going be fixed then?
I created these new ones recently to work better cross platform by copy/pasting the settings folder which is where all settings are now stored. The OptionsImport/OptionsExport already exists and may work well for some folks and work a bit differently so I haven’t touched them yet whilst the SettingsExport/SettingsImport is being tested in the WIP.
I can’t say
thanks @CallumSykes that sounds good, still now there are some redundant settings which are obviously neglected and people are going to fall into, maybe removing the other command then would help?
I want to see how well the new commands work first ![]()
