Options window cutting off Annotation Style settings
Over here, if I open Options -> Annotation Styles, select a style, then on the right hand side, expand Text, Dimension Lines, and Arrows, I can no longer scroll down past Length Units (so Angular Units, Leaders, and Tolerance are hidden).
Thanks,
Sam
I see that.
I’ll get it buggified.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36403
What’s odd is if I start expanding the panels from the bottom going up, then the elevator bar resizes appropriately so I can slide up and down the panels.
RH-36403 is fixed in the latest WIP
