I appreciate the resizable Options dialog. However, if its resized to be very tall and once clicked OK, it opens like this:
c.
c.
Another couple of glitches in the resizable mechanism…
Edit - I guess the second example is not clear, when you have a long file path (not shown in the window) the path window does not expand (IMO, it should)
–Mitch
Hi Mitch - as far as I can see, these are fixed in the build Du Jour that I have here- no idea if this is just luck or if something was actually worked on, but please try the next build and let me know if you still see it.
thanks,
I worked on this last week and it should be fixed in the next release
http://mcneel.myjetbrains.com/youtrack/issue/RH-28341
I am really liking the resizable options, but I was wondering if it would be possible to make the divider between the right and left pane repositionable. If you have long display mode titles, they can get truncated.
Thanks,
Sam
