Options / Appearance Broken
WIP V9 (9.0.25343.14055, 2025-12-09)
Can’t change the font, font size, any of the colors.
The entries are accepted in the dialog, and stay there, but nothing actually changes.
I’m assuming you are using the new commandline UI (use TestEtoCommandUI to verify)
The text and color options in appearance (currently) only work for History mode. If you are using the command search mode or Side bar mode, the options will have no effect.
Thanks -
Yes, it’s in History mode.
Doesn’t work ….
Then it might have been fixed in the past two weeks, since here it’s working. A new WIP will be out today
Yes, that fixed it, BUT..
I can’t change the color of an object (eg a line) from the properties display color..
