transformations (matrix transformations) have move scale orient mirror
have copy = yes/no
many other deformations project (to a curved surface), pull
have delete input = yes / no
projectToCplane is a matrix transformation but has delete yes/no as a forced step, not as a repeated (optional modified) option.
delete / copy both answer the same question
“shall i replace the existing geometry with the new position/transformation/shape ?”
on the first view it looks like a paper-cut, that makes learning more complicated - the more i think about i feel like there is a consistent concept missing.
… i will come up with more examples while working…stumble across…
thanks for the list.
best - tom
If the command makes a 1:1 identical copy, copy seems the right keyword. When the input is deformed or converted to something else, delete seems a better keyword.
copy = no change / delete = new shape…
yep - maybe this is the correct way to look at it
… scaleNU will change shape but has copy option
where i really hassle:
_extractSrf example above:
delete = yes = modify
delete = no = new geometry
(and i will bring more examples where this naming / wording is not hitting the exact behaviour…- but i also do not claim to have a great alternative.
maybe: CreateNew (copy = yes, delete = no)
(which will require some polish for _extractSrf)
seems like a minor compromise to me. Scale, even non uniform, will keep the shape in tact, and can be reverse transformed into the original. The structure of the object doesn’t change
