Hello all,
This is my first time trying to use Wallacei X for optimizing energy use and daylight. If I want to maximize UDI and minimize EUI and then plug them into the Wallacei component, do I still need to inverse the number output from EUI? If so, how to find the original numbers after finishing the simulation?
the following video would help you with this question
I greatly appreciate your reply, Milad.
I have seen this tutorial before, but from what I understand, it is a single objective. Once you maximized it and another minimized it, didn’t you?
The simulation only yielded one objective output (maximization), and it did not display the other objective that requires minimization. Is there any missing?
I attached screenshots of what I got from the simulation.
Double-check your second objective and verify whether the value changes when you manually adjust the genes. The issue arises because your second objective value remains constant throughout the simulation, which is evident from the flat mean trend line
