Optimized vectorization
Hello I am working with vector images to convert them to plots in Rhino.
The problem with vectorization in Illustrator is that it will make two paths from a felt line. Is there a method to have only one clean line ?
Ideally I try to have the same result as if I were tracing my drawing.
You need to modify the trace settings, and you may need to pad the image with some white space
Do you use Adobe Illustrator ?
Thanks, it’s in illustrator. I believe this is also possible with Inkscape. :+1:
