Optimization of Continuous Horizontal Louvres
Hi everyone, sorry if this is the wrong place to ask for help. I’m trying to figure out how to use grasshopper to make a louvres ,so i can later use Galapagos to optimise for shading, like in the picture, that flow across three sides of the rectangle but i have no idea how to make it continuous in fact i have no idea at all. Any and all help is appreciated
Hi @Meirzan
What are you planning to optimize for? What do you want Galapagos to solve for?
The answer to those questions is important for the right approach to scripting that canopy
The louvres describe a simple ruled surface. You cannot design this without some analysis tool like Ladybug for solar radiation, daylight availability, glare control, thermal gain, etc. …
P.S. Your laptop has a screenprint button.
hi @Volker_Rakow @Nick_Leung
Thanks for the fast replies.
Realized i might be getting too ahead of my self. I am planning to optimize for glare control and solar radiation for my studio project. as of right now im trying to understand how to make the points flow between the specified three sides of the curve, i have experimented with using cull index but i end up with the arrayed points all following in the y axis instead of converging into the centre if that makes any sense.
P.S. i will remember to printscreen in the future lol.
You need a strategy. Pencil and paper. Think it through.
Your question is effectively, how do I turn the corner in terms of construction. Personally, I wouldn’t bother angling the outriggers though the corner, but just let one brise-soleil run under the other.
You’re probably right, i can model it in rhino 8 but i wanted to show off in my crit next month lol. i’ll do as you suggested then in my free time see if i can get it to work thanks for the advice :slight_smile:
Yeah, you need to be very specific with what you want to achieve with Galapagos, because effectively all it does is move sliders around to make a number at the end of your script either as big or as small as possible.
But how do your sliders affect your script?
Is your canopy going to be static, you build it once and you want the best position to provide shading for your window?
Because this can get very complex very quickly. The sun has a pretty complex trajectory throughout the year. Do you care about a particular time of day? Time of year? Location matters as well of course. If this is a hot climate, you may want to optimize just the times of day and year that it’s hottest. If you have a particular program that needs to be safe from direct sun at a particular time of day, your results will look very different. The approach will be different.
Maybe you have a fixed budget, so a fixed amount of material, so you want to understand what angles to place each canopy to provide as much shading as possible to particular windows..
Thing’s obviously get more complicated if the canopy can move as well. Then you might be trying to figure out what angles become useful and which ones aren’t. You may also want to figure out if creating a moving system even has a meaningful impact on result, but that depends entirely on the performance you want to optimize for.
It could very well be that the best solution ends up being a tinted film on the windows instead.
@Meirzan, you should show us a hand-drawn sketch (not the building precedent) of your intention :wink:
If you can draw it, you can model it. Grasshopper is the “easy” part.
As a novice myself these little ‘side quests’ are always what I enjoy the most about projects.
How would you start the louvre system in Rhino by hand? I bet you can describe it in a sentence or two.
And, though I understand this fun intention, something (costly) that comes with inexperience is precisely showing off the tool instead of the work that got you there. You never know when a “grasshopper guru” that can disarm you in a crit will sit at your review.
Be careful!
What are the three sides? Where is your file?
