Hello I have a question.
I’m using Rhinoceros7.
If you change the position of the created dimensions or select multiple dimensions, the operation of the PC will become heavy each time.
Is this a problem with my PC?
If you have a similar problem, please tell me how to solve it.
Hello - please run the SystemInfo
command in Rhino and copy/paste the results here.
Mr Pascal
I’m sorry I didn’t notice the contact.
If you notice this reply, please tell me how to solve it.
Thank you.
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Commercial、ビルド 2021-05-07
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.1.0.0\XNurbsRhino7\XNurbsRhino7.rhp “XNurbs”
C:\Users\ITOHIROKI\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18347.11581\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18347.11581
C:\Users\ITOHIROKI\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Users\ITOHIROKI\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
Hi Hiroki
Please update your Rhino installation. You can find the latest version by going to Rhino Options -> Updates and Statistics
in Rhino.
If you continue to have issues, please try to disable these non-standard plug-ins and see if that help.
If not, post a 3dm file that you are having issues with on your system.
Mr wim
Thank you for your reply.
I will try as you told me. Thank you!
