Opens scales on a subd surface
ey!, i saw this imagene for a pavilion that was created by fast + epp, the name is “the perch”, so i want no know how to build this on grasghopper in a created base by a surface subd. I want to put this skin with open scales on my subd surface. Someone know how to do this??
A possible solution.
thanks a lot for your answer sir, but one question…what is the pluggin for “Quad Surface”?
Superficie + | Food4Rhino
oh man, thanks a lot you save my project, now… i fix some things to do that the scales open to just one side, in another point, if you use a subd by rhino, you can used their panels only put the comand “extractcontrolpolygon” and used this mesh in the definition on grassghopper.
sorry my bad inglish but i uploud the definition if you want to used, again thanks a lot for your help.
open scale skin.gh (13.8 KB)
