Might there be a bug in the OpenNest Unroll component?
I input some Text and some Points (Location) and the output is empty.
Also, I think the outputs ‘TXT L’ and ‘TXT’ have reversed positions respect to the Inputs.
But if you are trying to unroll one closed object, be sure that surfaces are joined. If it is one object as a brep it is treated as one object. I assume that you have 4 timber plates, not one.
I did check it looking for answers but there in the file “OpenNestExample191004.gh” there is not example of the Unroll component using TXT and TP inputs.
