Tried to nest some closed curves which contains other curves and text inside and ended with a mess on text transform. Any suggestion?
01.3dm (1.1 MB)
01.gh (20.6 KB)
I highly suggest to use OpenNest2 for custom attributes for Rhino8.
Elements there have attribute parameter to avoid this data tree matching issue.
Unfortunately, have no win11 machine available. Is there a solution with current setup?
Yes there is, I will write answer when I am home, I am currently on Ubuntu…
Hi @Petras_Vestartas , anything on this?
On the old version you would need to do the following:
- Create polylines as outlines.
- References everything to grasshopper as guids.
- Transform everything.
Here is the example:
Your text:
polylines.gh (27.8 KB)
polylines.3dm (2.7 MB)
Thanks Petras! Works excellent.
