OpenNest Solver with Hops
Hi @Petras_Vestartas
I´m trying to run OpenNest with hops but I´m running into some issues:
I thought the opennest solver is static akin to the K2 Zombie solver, so it should work. Any idea why it doesn´t?
Cheers, -David
Total guess here since I do not have access to the OpenNest GHA source.
RhinoDoc.ActiveDoc is typically null when running in rhino.compute. This is usually where I’ve seen plug-ins fail as they are attempting to do something like get the tolerance off of the active doc. Grasshopper has some helper functions for this to return a consistent tolerance when no active doc exists.
You can try to run opennest using from .dll. i think there is a sample on github.
Could you please elaborate on this? I’m not sure how to run from .dll and could not find a sample on github!
thanks you!
