Opening Named Views out of memory error
I’m working on a fairly large file with iRay rendering, and I think due to that(maybe??)now I can’t open the NamedView panel without a memory allocation error and crash. This should not be possible.
Hi Jim - if all views are wireframe, does that work?
No, they decide to shade themselves.
Just a thought in the dark - open an empty Rhino, open the named views, set the panel to show the list rather than thumbnails, then try your file…?
That did work thanks!
@andy - fyi… I do not have IRay here to test and buggify this.
Well it’s probably something with iRay, or just that 32GB isn’t a huge amount of RAM anymore.
Update: Well maybe not, 'cause trying to reproduce it I’m getting a memory allocation error just on opening the file…
Well I finally seem to have found the source of the massive RAM demand, it’s the HDR environment. One one had I would expect that, I am using a large one, but I am asking iRay support if the numbers really make sense.
