VisualARQ is a great plugin, but I’m having a small problem. When I open a door in VisualARQ using the properties, everything looks fine in Rhino. However, in my LiveSync to Lumion, the doors appear both open and closed at the same time. It seems like there are two doors—one open and one closed—perfectly overlapping each other.
Since we can’t select objects in Lumion like we do in Rhino, I can’t delete the duplicate. In Rhino, however, everything looks perfectly fine.
Hi @Faruk_Atac this seems an issue related to the refreshment of the geometry in the Lumion viewport. How long do the two doors appear, if you keep working on the file? If you save the file, and restart Lumion, do you still see the two doors?
We need to investigate if there is anything we can do from our team to make it work better.
