OpenCL for Raytraced temporarily disabled
I wanted to let users/testers of the Raytraced mode know that OpenCL rendering isn’t currently supported. I thought I had posted about that, but I can’t find that topic anymore, so here is to make sure people with non-CUDA GPUs are aware that for them it is currently CPU rendering.
Fear not, I will make a push to get OpenCL rendering back online at some point!
/Nathan
is it enabled again? if not, can you tell when?
You can still manually select OpenCL devices, but the setting doesn’t stick between sessions. The rendering with OpenCL devices I test on my AMD R9 270x machine, there it seems to be working.
I don’t know yet when the OpenCL support will be enabled by default, but you can be sure I’ll write about it when it is turned on.
/Nathan
OK, thank you.
I was curious before trying the WIP the first time on my little home-computer. In the office I’ll keep Rhino5 for now.
The home-computer has a very weak AMD APU. But like you said, I was able to set the OpenCL device and it seems to work.
