Windows explorer win7 64bit pro, right click on an stl file, choose open with, choose ‘other programs’ and select rhino icon and wording rhino5, rhino opens, but its Rhino4.
Why ?
Whats happening, how do I get it to select Rhino5 ?
Also, the 64-bit version of Rhino 5 has an “Original filename” of rhino4.exe as you can see here:
So, depending on where you are looking, you will find rhino4 even if you are running RH5.
the steps I took which I wrote out were accurate.
I was in windows explorer, I right clicked on the stl file icon, selected ‘open with’ , then selected ‘other program’ and clicked the + in a box to expand, and I am faced with the screenshot attached, I selected Rhinoceros 5 and it launched rhino4.
I was puzzled as to why, when selecting the Rhinoceros 5 icon, it launched rhino4.
here is the screen dump of the point at which I chose what I thought was rhino5.
Allow me to add to the confusion - though only partially related…
On my system, I have Rhino 5 (32 & 64-bit) and the WIP installed. RMB on an .stl file in Windows Explorer and pick Open with. When I expand the Other Programs window, I can see both the Rhinoceros 5 and Rhino WIP options:
Now, click the Browse… button in the Open with dialog and browse to the directory of the RH5 64-bit installation, select the Rhino.exe file and hit Open.
I now have two “Rhino WIP” entries, one of which is selected and - I suppose - is actually a Rhino 5 instance:
You can now go through that same procedure once more and you’ll end up with yet another “Rhino WIP” entry.
Yes, there is something wrong here and has been for a long time… Another symptom - when dragging a file onto a desktop shortcut, ALL my Rhino icons (for different schemes and such) now show “Open with Rhino WIP” - including all my V5 icons…
