Hi!
I am trying to open a .pat file in rhino 5.0 educational but when I open it I get the following error:
“File type not supported by Rhinoceros”.
Is this due to my student license?
Kind regards,
Mike
Hi!
Kind regards,
Mike
No - student licenses are the same as commercial ones.
Normally you don’t open .pat files directly, you import them via
DocumentProperties>Linetypes>Import (linetypes)
or
DocumentProperties>Hatch>Import (hatches)
–Mitch
When I opened the file on my colleague’s computer it just opened directly after the message: “Convert Rhino coordinate system?”
The .Pat file is an outline of a vessel which I want to have in Rhino.
OK, this is not a linetype or hatch then… I don’t see .pat as a supported file type for importing in standard Rhino, are you using a plug-in? what program generated the .pat file?
I don’t know what program generated the file.
I’m following a tutorial but my professor also doesn’t know it.
I checked if he had a pat plug-in or something but that is also not the case
I went to IT and they gave me some plug-ins as you mentioned. It should work after that.
Thank you for your time!
