Open Object
Hello there,
Since my last question on here helped me a lot, I thought I’d give it another try.
I have some objects which are shown as not being closed. Using the command ShowEdges shows that some points where my curves meet are open. Is there an easy fix? Is the reason my radii meet too closely?
Best regards and thanks in advance.
Try the command _RemoveAllNakedMicroEdges.
Thank you very much for the reply.
It seems to have solved the problem in most cases. :slight_smile:
