Open Nest no longer supported?
Hi Guys,
All of my scripts running on Shapediver use the TXT component in Opennest.
I uploaded a new Script on the 22nd with no issues.
Today I go to do an update and get this:
Can you fix this please?
Cheers
DK
I think they had issue with version control.
I added a correct Assembly number and uploaded on food4rhino 1.3.3:
@Petras_Vestartas thank you very much for the update - I’ve been able to update again to SD.
I have a ‘bug’ which you might be able to help me with.
I use your ‘Text’ component all over my code to display useful information and mark up panels.
The previous version had a very nice default display:
Now I get a very blocky/hard to read default esp on numbers:
Is there a work around or could you have a look at this for me?
Cheers
DK
In last version you have option to specify text font.
Example files shows how to use it.
Hi @Petras_Vestartas
Thanks for that - could you tell me which font was that nice single line font that was the default in the past?
Cheers
DK
In the current version I skipped this line font, because it cause super slow speed in laser engraving.
Since we used a laser cutter that does not like arcs very much.
But you can use typical fonts such as
https://wiki.mcneel.com/rhino/engravingfonts
This font is shipped with Rhino
