I have many STL files I would like to open in Rhino at once. However, it’s not possible to select multiple files in window for import file selection (File -> Import). Could you tell me how to import multiple geometry files?
Assuming you are on Windows, in the Windows file explorer, select all the files you want to open and drag and drop them into a running Rhino instance window. You will get a dialog if you want to Open, Import, or Insert the files, choose Import. I think you will have to hit the OK button for each file though.
Hi Helvetosaur,
Thank you for your prompt reply.
I could import the multiple geometry files into Rhino according to your instruction!
Thanks again.
