I’m running into a problem as I try to turn two surfaces into a closed brep by lofting between their edges. I use the DeBrep component to get the surface edges in order to loft between them (so I can then join everything together into a Closed Brep) but I’m getting an error because the edge curves are open. Do you know why the curves are open and/or how I can get the edge curves to be closed? I’ve attached the definition for as well. Thank you for the help!
open_curves_problem.gh (392.1 KB)
