Open Compact grasshopper window for quickly change parameter
Quickly open mini grasshopper window like below-
User first need to create Views inside grasshopper, like below-
Here is the video explaining the Workflow-
you can “publish” sliders and stuff to the remote control panel, here is a quick guide:
Thanks for the video, I know there are also other extensions like Xpanel is there but we memorise our node graph while working on it and hence it is convenient to use same window. Also for adjusting parameters in those extensions, we need to first make panels with proper names and xpanel only allow sliders. we need quick working solution so it work with other things like rhino.inside as well.
