I am having a problem with grasshopper not recognising certain type of BREP’s being closed.
The issue occurs always when two parts of one BREP meet each other just at the corner.
(see images below)
That is correct. They are converted from meshes. I am trying to find out the best workflow.
The buildings have to be put together (joined,union) with the ground floor. With “Mesh Union” i do not have very good experiences.
But apart from that I think the problem described above would be nice to be solved.
Clean better your meshes before converting them to breps. Use Align + Combine&Clean.
You have a lot of non-manifold edges. Edges are not aligned. etc etc
