Opacity Crash
Current version of WIP is crashing when changing Opacity on the picture function.
Hi sierradays - does the current viewport display mode make a difference? Does this happen in any mode?
Hi Pascal,
I was using Render Mode to see throught part. I didnt try in other render
modes. The problem stopped when I switched out of Cycles.
Thanks
Dave
Hi SierraDays - sorry, I’m not sure I follow - did you set the picture object to use Rendered display mode (SetObjectdisplayMode) or are you using ‘Render Mode’ to indicate Raytraced (i.e.Cycles)?
