I use the equivalent of the code below to iterate through layers, and when I identify a layer of interest, then iterate through model geometry components looking for those that match the layer index, and when I find one, if it is an ON_Brep, I then create a new ON_Brep and add it to the layer.
The problem is when I add the new ON_Brep, the next call to my layer component iterator returns nullptr, and so I exit the loop prior to when I expect (that is, exit prior to iterating through all the layers). Is this a bug?
I haven’t investigated whether this also occurs for the next call to my model geometry iterator, mainly because in my layers of interest there is only one ON_Brep of interest, so only the problem with my layer component iterator is explicitly observable.
My code is effectively this:
ONX_ModelComponentIterator it_layer(geometry_model_, ON_ModelComponent::Type::Layer);
for (const ON_Layer* layer = ON_Layer::Cast(it_layer.FirstComponent()); nullptr != layer; layer = ON_Layer::Cast(it_layer.NextComponent()))
if (layer->IsVisible() && (isFractureBody(ON_String(layer->Name()).Array()))) // only consider visible layers that are fractures
ONX_ModelComponentIterator it_modelgeometry(geometry_model_, ON_ModelComponent::Type::ModelGeometry);
for (const ON_ModelComponent* model_component = it_modelgeometry.FirstComponent(); nullptr != model_component; model_component = it_modelgeometry.NextComponent())
const ON_ModelGeometryComponent* model_geometry = ON_ModelGeometryComponent::Cast(model_component);
if (model_geometry->Attributes(nullptr)->m_layer_index == layer->Index())
const ON_Brep* brep_frac = ON_Brep::Cast(model_geometry->Geometry(nullptr));
if (brep_frac != nullptr)
// create geometry object then add it to layer using:
ON_3dmObjectAttributes* attributes = new ON_3dmObjectAttributes();
attributes->m_layer_index = layer->Index();
bool rc = !geometry_model_.AddManagedModelGeometryComponent(geometry_object, attributes).IsEmpty();
