ONX_Model::ModelGeometryFromXXX functions not implemented?
I’m trying to update my code from openNURBS 5.0 to openNURBS 6.0, and it’s requiring a huge number of changes. One problem seems to be that the various “table” arrays for things in the ONX_Model have gone away.
I was just trying to replace
onx_model->m_object_table [index]
with
onx_model->ModelGeometryFromUnsignedIndex (index)
My immediate problem with this is that ModelGeometryFromUnsignedIndex isn’t declared const, which is tripping up my code. But when I tried to look at the implementation and see whether its un-const-ness was required, I discovered there is no implementation?! If I do
ack ModelGeometryFrom
all I get is
opennurbs_extensions.h
1249:  ON_ModelGeometryComponent ModelGeometryFromIndex(
1252:  ON_ModelGeometryComponent ModelGeometryFromUnsignedIndex(
1255:  ON_ModelGeometryComponent ModelGeometryFromId(
ie each of them appears only once, and they have no function body anywhere?
Hi @colomon,
When moving from openNURBS 5 to 6, it’s best to convert your for loops that iterated the old tables, found on ONX_Model, to model component iterators. For example, to iterate the model geometry you can do this:
ONX_Model model;
ONX_ModelComponentIterator it(model, ON_ModelComponent::Type::ModelGeometry);
const ON_ModelComponent* model_component = nullptr;
for (model_component = it.FirstComponent(); nullptr != model_component; model_component = it.NextComponent())
  const ON_ModelGeometryComponent* model_geometry = ON_ModelGeometryComponent::Cast(model_component);
  if (nullptr != model_geometry)
    const ON_3dmObjectAttributes* attributes = model_geometry->Attributes(nullptr);
    if (nullptr != attributes && !attributes->IsInstanceDefinitionObject())
      const ON_Geometry* geometry = model_geometry->Geometry(nullptr);
      if (nullptr != geometry)
        bool rc = ProcessModelGeometry(geometry, attributes);
        // TODO...
To iterate a different ‘table’, just create an model component iterator and and specify a different model component type (enum).
Does this help?
– Dale
That doesn’t really help, as I am actually trying to do random access lookup via the index here rather than iterating through everything.
I’m not seeing any obvious reason I cannot just store an ON_Object pointer instead of the index here, which I guess should be a reasonable workaround for what I need.
Hi @colomon,
Use:
ON_ModelComponentReference ComponentFromIndex(
    ON_ModelComponent::Type component_type,
    int component_model_index
    ) const;
ON_ModelComponentReference ComponentFromUnsignedIndex(
    unsigned int component_model_index
    ) const;
ON_ModelComponentReference ComponentFromId(
    ON_UUID component_model_id
    ) const;
For example:
const ON_ModelComponentReference& model_component_ref = model.ComponentFromId(ON_ModelComponent::Type::ModelGeometry, geometry_id);
const ON_ModelGeometryComponent* model_geometry = ON_ModelGeometryComponent::Cast(model_component_ref.ModelComponent());
     // TODO....
– Dale
Index wasn’t working for me at all, but I changed things to use the iterator to go over the entire file and then used the UUID as a random access pointer, and that seems to be working for me.
