When using Oneview and shifting between perspective and right view (and back to perspective) changes the camera lens length to 50 mm - even if I had it set to 100 mm. I think it should keep the original lens length. That’s a bug to me…
From a deep dive into the depths of YouTrack, I see that this might be by design. The same thing happens when you set the “Projection” from “Perspective” to “Parallel” and back to “Perspective” in the Properties panel.
It used to be that doing this (either way) would always set the lens length to a hard-coded 50 mm. It was changed in Rhino 7.0 in 2020 to revert to the default camera lens length that is set in Rhino Settings -> View.
If you always work with 100 mm, you could set this as the default instead of the current 50 mm.
I’ve put this on the list for an extra look.
→ RH-98428 Camera: Remember Perspective Lens Length per Viewport
Oh dear… I meant upper right corner, of course. Anyway…
I almost guessed that it might have been by design. A bad design decision IMHO, though. The program shouldn’t change anything behind the scenes that I don’t want - when I explicitly have selected another lens length. Not good.
