One shot Point snap broken in Rhino 8 WIP
Hi, One shot point snap is not working in Rhino 8 WIP.
In Rhino 7 it’s working as expected.
I can’t make heads or tails out of your video.
I drew a degree 3 curve and selected it to turn it’s control points on.
Then started the Circle command with several persistent osnaps on but not Point.
My circle seeking pointer did not latch on to the curve control points.
I typed “point”.
Then my mouse pointer DID latch on to the control points.
V7 did exactly the same thing.
I can not duplicate your described issue.
Please reply back with steps to follow (like mine) to illustrate the problem you’re seeing.
Thanks for the find. I was able to repeat and have created a ticket.
https://mcneel.myjetbrains.com/youtrack/issue/RH-75320/OSnap-One-Shot-Point-snap-doesnt-get-set-when-clicked.
@Trav
What did I miss?
Start the Move command and hold Shift and click Point in the OSnap panel. It should pass _PointSnap onto the command line during the move command and instead it does nothing because I broke it. :melting_face:
