Hi!!! I’m just getting mad, trying to get a pool slide, in rhino… so, I have a sort of spiraled curve, which is the path, and the section curve, a bit complicated, not just an half circle, as they are the edges of the slide… sound simple, but in fact the shape turn on itself… how to get a constant , similar orientation of the section curve, all the rail long???
thank you for help!!!
In the Sweep1 Rail Options menu, select “Road-like Top” for the style. This should keep the section curve oriented correctly.
