I have a simple attractor script. When I append the ‘i’ and ‘j’ loop values to tuples in the main list, I am unable to use the tuples as point3D objects. I thought that many functions that required 3d point objects would also accepts tuples.
Anyway, when I create another for loop and choose the ‘ptlist[i]’, it somehow transforms the tuples into point3D objects. This, I don’t understand.
#import random
ptList = []
rs.EnableRedraw(False)
def pointMatrix():
iMax = 20
jMax = 20
k = 0
testPt = rs.GetObject('select Attractor pt', rs.filter.point)
#loop to create list of short values
for i in range(iMax):
for j in range(jMax):
x = i
y = j
z = k
ptList.append([x,y,z])
#loop to create circles
for i in range(len(ptList)):
distance = rs.Distance(testPt, ptList[i])
radius = distance / 20
if radius > .5:
radius = .5
elif radius < .125:
radius = .125
rs.AddCircle(ptList[i], radius)
print(ptList[i])
#here the tuples are now point3D objects or read that way
pointMatrix()
Incidentally, I am attempting to create a two-dimensional matrix with this code. Is this simple? Should I define a two- dimensional matrix like this?
grid = [[0]*8 for n in range(8)]
for row in grid:
for col in row:
No, they are still lists (not tuples). Nothing has changed them into 3d point objects. Try the following:
pt_a=rs.coerce3dpoint([0,0,0])
pt_b=[0,0,0]
pt_c=(0,0,0)
print "pt_a is a {}".format(type(pt_a))
print "pt_b is a {}".format(type(pt_b))
print "pt_c is a {}".format(type(pt_c))
pt_a is a <type 'Point3d'>
pt_b is a <type 'list'>
pt_c is a <type 'tuple'>
BTW,
Tuples look like this
(x,y,z)
Lists look like this:
[x,y,z]
Tuples are immutable - you cannot change the value of their elements
List elements can be changed.
HTH, --Mitch
Thank you Helvetosaur,
I understand and I appreciate the corrections; however, I still am not certain as to why this segment of the code does not return acceptable lists.
I assume it is because they are of incremented lengths? I would assume that the ‘i’ and ‘j’ for loops would return a 2-dimensional array; however, it seems that the third for loop translates the incremented list into a one dimensional list.
In the above suggestions are you implying to replace:
with
ptList = rs.coerce3dpoint(x,y,z)]
If you already answered this, I apologize. Here is the code that is returning lists of incrementing lengths which are confusing. Thank you for your help.
import random
ptList = []
def pointMatrix():
iMax = 20
jMax = 20
k = 0
x = i
y = j
z = k
print(ptList)
pointMatrix()
No, that is not the case… Why? Because in the above, you are still only creating one flat list - every “point” is simply appended to the main “ptList” in the same way. If you are trying to create a nested list, you would still use a double for loop, but you would need to go about it in a different manner:
def PointMatrix(i_max,j_max,k):
#create empty main list
main_list = []
for i in range(i_max):
#on each i loop iteration, create new empty sublist
sub_list=[]
for j in range(j_max):
x = i
y = j
z = k
#append j loop points to sublist
sub_list.append([x,y,z])
#at the end of each i iteration, append the "j" sublist to the main list
main_list.append(sub_list)
return main_list
for item in PointMatrix(20,20,0): print item
Edit: for compactness, instead of x=, y=, z=, you also can assign point values directly like this:
sub_list.append([i,j,k])
Hope this helps, --Mitch
Ahh ok this makes sense.
It is cleared up. As always a huge help! Thanks again for posting the example.
Erik
