Here’s a is a simple wall object. I made two materials from imported images, paneling and brick/tile. Neither works as expected. I applied the paneling on the left side wall and it is correct. Applying the SAME material on the right side and it rotated 90 degrees? Why, I changed nothing?
I made the tile image for 3x12 tiles. I imported and applied it. On the front and side of the protruding pony wall, the size is as expected, but aligning the faces is impossible as the U-V offset does not work to move it. Moreover, the same material is applied to the inside faces, and the scale is much larger. Shouldn’t the same material display with the same properties on objects?
Further, I made the two custom materials, but two additional “Custom” materials appear in the panel. It seems they are somehow linked to the materials I made, because If I try to delete them, those materials are also deleted.
WALL.3dm (1006.6 KB)
