Having trouble getting the ON_NurbsSurface srf.Split method to work. Parameter 3 is looking for a reference to a pointer(??) so getting compiler error. I implemented code from the example in the opennurbs_nurbssurface.h file and can’t get it to work.
Example:
int dir = 1;
ON_NurbsSurface* south_side = 0;
ON_NurbsSurface* north_side = 0;
nurbs_srf->Split( dir, nurbs_srf->Domain(dir).Mid(), south_side, north_side );
Compiler error I’m getting is: error C2664: ‘ON_NurbsSurface::Split’ : cannot convert parameter 3 from ‘ON_NurbsSurface *’ to ‘ON_Surface *&’
After googeling references to pointers in function arguments I implemented the code as suggested:
int dir = 1;
ON_NurbsSurface south_side = 0;
ON_NurbsSurface* psouth_side = &south_side;
nurbs_srf->Split( dir, nurbs_srf->Domain(dir).Mid(), &psouth_side, north_side ); and still doesn’t work.
Compiler doesn’t like the reference to pointer:
error C2664: ‘ON_NurbsSurface::Split’ : cannot convert parameter 3 from ‘ON_NurbsSurface **’ to ‘ON_Surface *&’
Can’t figure out what to do. Have any suggestions?
Yes, it does thank you! Code is compiling now.
Sort of an oversight on my part since the function is asking for these parameters:
ON_BOOL32 Split(
int dir,
double c,
ON_Surface*& west_or_south_side,
ON_Surface*& east_or_north_side
) const;
However, the example right above it shows using ON_NurbsSurface* south_side = 0;. Might want to clean up the .h file before next release.
I thought since ON_NurbsSurface is an inherited class from ON_Surface it would work.
Dale,
Again thank you. Now I would like a different point other than the Mid() point. I have points on the surface I have evaluated using EvPoint and would like to use one of those points as the location to split the surface. Unsuccessful in implementation. Is there a method that does this?
ON_Surface::EvPoint evaluates a surface at a u,v parameter and returns a 3-D point. ON_Surface::Split want, as input either a u or v parameter depending on the direction of the splitting. So if you have a 3-D point that you want to split at, you will need to use ON_Surface::GetClosestPoint to obtain the u,v parameter that is closest to the test point.
If you are using the standalone openNURBS toolkit, this will be a problem as ON_Surface::GetClosestPoint is not implemented.
