I need to use this method to join several Brep faces that have coincident edges, but it keeps giving invalid outputs.
Here I attach a sample that reproduces the problem: I’ve simplified it to a Brep that has 2 independent faces ABCD and EFGH which turn out to have coincident edges BC and EH.
// D---------e2-----C H---------e6-----G D---------e2-----C---------e6-----G
// e3 Face 0 e1 e7 Face 1 e5 ----> e3 Face 0 e1 Face 1 e5
// A-------e0------>B E-------e4------>F A-------e0------>B-------e4------>F
I thus join them in the code before adding to the document:
// Join coincident edges BC and EH
ON_BrepEdge* edgeBC = brep->Edge(BC);
ON_BrepEdge* edgeEH = brep->Edge(EH);
bool rc = brep->JoinEdges(*edgeBC, *edgeEH, DBL_EPSILON);
brep->Compact();
The result is not valid, though the members of the Brep are valid (or those that I checked, m_V, m_E, m_F, m_T, m_L, m_C3, m_C2, etc.).
What’s the issue here? Is there another way to do this in C++? A priori I need this method as in my code I always first have independent faces with common edges that I then have to somehow join.
Here the code & thx
Nathan
cmdJoiningEdges.cpp (13.6 KB)
