Сolored nesting
Hi. I made UnrollSrf boxes. I have a photo of a wooden shield. I want to create a model in which the pattern on the finished product is visible. I want the image on the box to change when moving parts on the shield. Can anyone tell me how to make such a dependent model?Can this be done in a Grasshopper or a Rhinoceros?
texture.3dm (1.1 MB)
Hi @Rob25 ,
I think you’re looking for UV mapping maybe. I’d switch the material type from Picture to Physically Based and then run the Unwrap command on the model choosing all edges as seams to separate at. Then use the UVeditor to see the resulting UV islands and edit them.
Thank you very much. Are there similar tools in the grasshopper? For example, if I have many such boxes and many different sheets of material?
Not at this time in default GH.
