Currently, I use Rhino 8.4 but the latest RiR version requires Rhino 8.21.
So where can I download Older version that Rhino 8.4 can support?
Hi Eyob,
We recommend the latest, and due to updates to the Revit .net version is required.
What Revit version are you targeting.
What is holding you back from updating Rhino?
Revit version is 25.0.2.419
My network speed here is really sluggish and i got tight schedule
Hi Eyob,
Unfortunately an older RiR won’t get you there — Revit 2025 runs on .NET 8, and the Rhino.Inside builds that support it have always required a newer Rhino than 8.4 (Rhino 8.11 at minimum, 8.21 for the current builds). Updating Rhino is the path.
The good news is it’s one installer download and a free update on your Rhino 8 license, no in-between versions needed. Kick it off at the end of the day and let it run —
then grab Rhino.Inside https://www.rhino3d.com/download/rhino.inside-revit/1/latest
Thank you
