Old UI Arrycrv comand
Hello
In rhino 6, the Arraycrv command draw a UI
like this
With rhino 7 the UI as
disappeared
doese existe a hiden old command in rhino 7 or
it’s possible to restore the Rhino 6 UI interface in rhino7?
Best regards
Hi -
No.
The old UI didn’t show a preview in the Rhino viewport and, thus, the command had to be updated.
RH-6445 lists the reasons why the dialog box was dropped:
1.) Other array-related command do not display a dialog box.
2.) The Mac and Windows dialog box are different, thus adding additional complication and code.
3.) The workflow of the dialog box has always been odd - you have to close the dialog to pick the roadlike normal direction.
Ok thanks for the explications
Regards
