I want to offset/thicken the grey curve into the red curve (the red curve should be a series of closed curves)
The issue is rhino cannot offset more than one curve at a time, and offsetting a self intersecting curve produces weird results. (offsetmultiple cannot cap or do bothsides)
Using pipe and then section/contour can work, but i prefer not to use this workflow.
Is there any way to do this in rhino/grasshopper?
Thanks, Kayne
I dont mind the capping style, it can be curved or flat
how many of those curves do you have ?
what are you use them for ?
ist this a one-time approach or a tool that needs robustness and performance ?
quick and dirty:
do it in illustrator - your offset is half the line thickness - create the outlines, combine the curve.
manually:
for less work join curves
offset both sides cap style round, important set trim to no / turn it of.
(a pity this is not possible with offset multiple)
Curve Boolean - all Region - unselect inner areas manually.
