Offsetting closed curve unexpectedly produces two curves
Offseting the below curve in GH for Rhino 8 unexpectedly results in two separate output curves. This did not occur in GH for Rhino 7. Any ideas why this might happen? Changing the corner style to “None” fixes the issue but I need this to be kept at “Sharp”.
The curves’ end points seem to be slightly misaligned.
You can do something like this:
Thanks for the reply. My input is a single, closed curve. The problem is that the offset component itself is producing disconnected curves.
Without sharing your file it is difficult to find the issue.
CurveOffsetIssue.gh (2.8 KB)
CurveOffsetIssue.3dm (86.2 KB)
First, you can internalize geometry. This means, you only need to share the *.gh definition.
Otherwise, i would avoid the native “OffsetCurve” at all costs. It’s slow and not very robust from my experience. This was 3 years ago, maybe it has improved. Nowadays, i just use the Clipper2 - Plugin. Clipper2GH | Food4Rhino
CurveOffsetIssue.gh (6.3 KB)
the offset works fine if you provide the offset plane, which is always good practice:
OffsetCurve_wants_an_offset_plane.gh (6.3 KB)
note that if you go through Clipper then that curve must become a Polyline, which means goodbye arcs
No, it does not work fine or as expected. I am trying to get the smaller curve (offset inwards), which still results in two separate curves.
Foregoing arcs (sing Clipper) is not an option for me. Again, the Rhino 7 component worked fine. I am wondering what changed in Rhino 8 to spawn this issue and whether it can be fixed or if there is a workaround using native components.
that might depend on the direction the curve is drawn
by flipping it (corners is set to 0=None) I get this in R8 SR4 (8.4.24037.15001, 2024-02-06)
OffsetCurve_wants_an_offset_plane.gh (8.0 KB)
usually, in cases like this (planar closed curves), where not always the direction a curve is drawn is something I can control, the best option is to offset both direction and pick the shorter of the two
[ohh, I thought I was editing my previous post… sorry for that]
Just wanted to retry and re-opened the file, but the output is now as expected. Find the sysinfo attached.
Summary
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Educational, build 2024-01-09
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 8-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.99
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-4-2023
Driver Version: 31.0.15.3699
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
Thanks for all the input!
Tried the above with SR3 and SR4 and unfortunately getting two detached curves in both releases. I have copied my sysinfo below.
@dn.aur, this is usually my approach as well (offset to both sides and pick shorter/longer based on needs). Unfortunately, flipping the curve (and multiplying the offset distance by -1) doesn’t fix the issue for me.
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.15
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.79
Primary OpenGL: NVIDIA RTX A3000 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.79
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-16-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-2-2023
Driver Version: 31.0.15.3779
Total Video Memory: 6 GB
Would like to bring up this post again. Is there anyone who might clarify whether this is a bug or expected behaviour?
Curve is not internalized.
Internalized the curve.
CurveOffsetIssue.gh (4.8 KB)
I believe this is fixed in Rhino 8 SR 5. You may need to update to the latest service release candidate. The original issue was logged here. Opening your definition with the latest Rhino 8 produces the expected result of a single, closed curve.
This fixed the issue, thanks Joshua!
