Hi! I have created a pattern with Grasshopper (thanks to you on a previous post) and now I want to achieve a pattern like this picture.
I got to the geometric pattern inside the shape, but I can’t figure out the offset and surfacing step.
Hi @siemen . After testing it for a while, i’m having trouble when the “radio” slider is set to 30 or so (and increasing “celdas” slider to match the figure), the pattern crashes and gets all messed up. I attach a figure below. Any idea on how to improve this?
Thanks a lot in advance
Yeah as I said I didn’t double check all the details. There might be some things that need to be fixed or improved. But I see I made a small mistake. The range component doesn’t create the correct amount of steps and I think this is what messes it up. Try adding this expression to the range component in the back of the definition.
