An offset surface of (0.5) Rhino has trouble running it.
(See how it behaves in this case “FormZ”, from 2:25 onwards, this software can generate a thickness).
We should revise this kind of situation in Rhino.
I had no problems making the canopy with thickness in Rhino as shown in the video. Used OffsetSrf for the thickness.
Canopy Solid DC 01.3dm (400.9 KB)
Do you have an example file where you had a problem?
In particular, I did not speak of this example, but of that before, that you can see in the video to about 2 minutes and 25 seconds.
In these cases Rhino is unable to reconstruct a solid with all surfaces perfectly united.
