_offsetSrf bothsides = yes “thickness”
_filletEdge with Radius = half thickness for both edges somehow does not give a nice 180 degree surface.
we still not have 3-tangent-Fillet.
so this is a special case of 3 tangent fillet - the filletsrf is always 180-degree, half a circle
the inital surface edge is (only nearly) the mid of the final half-round-fillet. This is where the struggle starts.
The real centerline of the pipe is a _offsetCrvOnSrf (red curve)
i suggest a few workflows
all somehow suffer from a academic point of view
all feel like bricolage
still miss a nice solution:
(1) filletSrf and mergeSrf
do 2 stripes of FilletEdge or filletSrf
untrimall, split, mergeSrf
… might result in a surface with unnecessary knots
(2) filletSrf sweep1
build a single filletSrf as helper
arc with 180 degree at start and end
sweep1 with “align with surface” option.
seams promissing but suffers from precision on the second surface.
(3) rim-surface edges + sweep2
the surface stripe at the right might serve as base for a sweep2
but this surface has torsion - so the torsion will be inherited to the 180 degree fillet
… quite a hassle
(4) rim-surface + X
anything that uses the rim / thickness-surface will suffer from its torsion
(5) pipe
anything based on pipe will suffer from an undefined surface-seam of pipe.
your go - my question
so what is your preferred workflow, what is your suggestion ?
a nice solution that does not feel like bricolage.
And that does not suffer from a 3 step workflow - where each step is only within document tolerance - but in the overall result is of tolerance.
I remember after starting to read this forum to find out “the Rhino way” for doing Alias/ICEM type things, that a forum user asked for a tri-tangent fillet, but someone from McNeel said that unfortunately it was not on the list of the devs.
What about extracting the middle isocurve of the thin surface (the one that builds the thickness of the wall) and trying that new fillet tool introduced in Rhino 8 (I forgot its name) with the isocurve as a target? That should be able to build half of the desired 180-degree fillet. Repeat the same process for the opposite side, and you get two fillets at 90-degree each meeting together with tangency. Or at least this is what it should be possible.
Then, you can merge both fillets with the “Round” option off. But I would leave them as separate fillets to keep the number of control points lower and allow easier modifications if needed.
Another option that may fail but worth trying is to build a fin surface from the same middle isocurve, where the fin distance is half of the offset distance. Then use the opposite end of the fin surface as an input edge to build a pipe. Then split the pipe where it touches both offset walls and pray for Rhino to be able to achieve tangency there.
thanks @Rhino_Bulgaria for digging in.
you mean _FilletSrfToRail
the ugly thing is, that those 2 arc-section-surfaces do not span 90 degree each.
depending on the mid-surface, one is <90 one is >90 degree.
And the one that is above 90 degree will be 2 span surface.
If curvature of the mid-surface is changing side, along the edge both surfaces will be 4 spans - but 2 spans would be enough
a bad thing about fin surface: they are multiknot.
pipe has its own torsion based on the centercurve, independent of the surface.
using pipe and trim will end up in an uggly nearly iso-curve like trim …
ok - this is the most satisfying - but not perfect - workflow i found:
create the center Curve (either the initial mid-Surface edge or _offestCrvOnSrf)
using this center Curve
build a _fin surface that is tangent to the mid-surface (selected in screenshot, yellow)
draw an starting 180-degree arc (selected in screenshot, yellow) _sweep1 along the fin’s surface edge(rail) the arc, use “Aling with Surface”
trim and join…
optional check result with _edgecontinuity (or globaledgecontinuity)
I hope Rhino’s devs will still look at the tool in ICEM/Catia. All these things, no matter what angle, or one, two, or three contact surfaces, are solved in seconds. Extremely useful.
