rhino 8
Version 8 (8.35.26251.13002, 2026-09-08)
_offsetSrf the gray surfaces with corner=round 4mm inward will result in the violett surfaces - but unjoind - see naked edges (cyan)
offsetSrf_fail.3dm (3.2 MB)
the curved surface is part of a torus, the other surface is planar.
gray/black surface is extracted from a boolean operation result…
(untrimming, shrinking / spliting, trim, join will fix the issue)
thought worth reporting to make the algorithm more robust
ok here are the untrimmed, un-shrunken, initial surfaces:
offsetSrf_fail_allSrfs.3dm (3.7 MB)
boolean union - delete top cap _offsetSrf 4 mm round inward to get the bad edge (on layer result)
