I do a lot of sheetmetal work and use the OffsetSrf command a lot. But I use it in two separate ways, to offset a surface and to make a solid from a surface. Is there a way to have two different commands so I don’t have to keep changing the surface to solid option all of the time.
Thanks
James
You would need to create two macros, one with each option, and use either toolbar buttons or aliases to run them.
! _OffsetSrf _Pause _Solid=_Yes
! _OffsetSrf _Pause _Solid=_No
–Mitch
Mitch, Thanks
James Crombie
Tel: 902-838-7011
Fax: 902 838 2833
james@marinenav.ca
This e-mail is confidential, may contain proprietary information of
MarineNav Ltd. and its operating divisions and may be
confidential or privileged. This e-mail should only be read, copied,
disseminated and/or used by the addressee.
If you have received this message in error please delete it, together with
any attachments, from your system.
