Offseting without delete
when
I offset a surface Solid= True \ without deleting = True \ Both side = False:
→ it create a new polysurface on the same layer
I offset a surface Solid= True \ without deleting = True \ Both side = True:
→ it create a new polysurface on the current layer…
it do that only on mine Rino V7?
Hello- I see that, thanks. Output should be on the current layer in both cases.
RH-66779 OffsetSrf: output layer adjustment
RH-66779 is fixed in Rhino 7 Service Release 15
