Offsetcrvonsrf
The rhinoceros version that I actually have crashes every time i try to use the command “offsetcrvonsrf” and “intersect”… Is there anyone who could help me please? thank you all
Hello- please run the Rhino command SystemInfo and copy/paste the results here.
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational Lab License, build 2021-08-10
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: FILIPPO-MAGINI
Computer platform: LAPTOP - Plugged in [87% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-8-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Ho copiato e incollato le informazioni su un file nuovo in cui non ho eseguito alcun comando. Ma nonostante ciò appena provo a fare intersect oppure offsetcrvonsrf (e probabilmente atri comandi che ancora non ho scoperto) crasha… Tuttavia operazioni come le boleane che penso prevedano un’intersezione per poter funzionare le esegue senza problemi…
Un’ultima cosa: ho già provato a disinstallare e reinstallare la versione di rhino6 ma il problema continua a sussistere.
Grazie mille per la disponibilità e spero che riusciate a capire dove sia il problema.
Hi Filippo -
This sounds like a known issue with V-Ray. Does the problem go away if you disable V-Ray in the plug-in manager and restart Rhino?
It works! thank you so much for your help!
