Offset undo within command wish
I use offset a lot and for V6 I wish there was an undo command within offset similar to the way trim works. In fact I don’t think this should be a one shot command but should be similar to trim.
I realize offset now is a one shot command but I do so many of them I have the repeat * setting on the command. This way I can offset a variety of curves without having to re-invoke the offset command all the time but many times I have curves that overlap and occasionally I select the wrong curve I then have to cancel the repeating offset command and hit undo.
For the future I would like offset to work similar to trim, that offset be allowed to work with multiple curves or when prefixed with the repeating * command that undo be allowed to work within the command similar to trim.
RM
+1
Norbert
@pascal any chance this can get added to the wishlist?
Thanks,
RM
Yep. Added as
http://mcneel.myjetbrains.com/youtrack/issue/RH-27300
These are not visible to the public, yet.
thanks,
Thanks Pascal
