Could you eliminate the “offset srf variable” command and include the options “add handles”, “link handles” and “side tangency” at the command “offset srf”?
Currently the variable offset surface command has little utility, in my opinion it is a redundant command that could be fused with the normal offest surface command…
(with a change to the command code).
It could be an idea for Rhino v7…
