Hello everyone
I submit to you the drawing of a star whose offset does not work every time. it works only for numbers whose division by two gives an even number (4,8,12,16,20 … etc). I tested different approaches but without solution. Someone has an idea where the problem is coming from.
Thank you
Clipper works better in all cases. But your “star” pattern varies quite a bit depending on the ‘Radial Number’ slider, consisting of between one and four separate polylines.
