Hi, On my Setup it stays hung with solid=yes. Sr16
Thanks Mark
Hello - from the Solid menu that is expected; if you only run the command from the command line and set it there, it should remember your last setting in the session.
Hi Pascal, I was offsetting surface and could not change it to solid=no. I just wanted to see if it was something I was doing wrong. I thought while in the command you could toggle it yes or no. I did not take the time to troubleshoot the command. I was only making my situation aware to the forum to see if it not just me. —-Mark
